Earlier longer grip
john.nash
Earlier longer grip
Post by john.nash »
This came with an wng project.
I am using 7/8" bars with the two shims in the fork clamp ( the damper is deleted so likely correct).
The throttle tube is 7/8" but the clamp is 1" ?
Is this how they were originally for the tapered bars ?
I'll have to shim the clamp bit, to fit the 7/8" bars, and find/make the insert for the cable .
Shown next to a standard later tube. The cable bit is brass.
John Nash
AOMCC No.4119
alan.moore
Re: Earlier longer grip
Post by alan.moore »
John,
Lucky chap, those long throttles are quite rare.
The bars were 7/8" from the end of the taper so I think you just have a mis-matched 1" twistgrip 'body' with your 7/8" twistgrip.
This pic shows that, although the wrong size, the body you have is the correct style. I should think you will be able to pick up a 7/8" Amal body as that size is quite common.
And a pic of an original RN WNG
Alan
