6560-41 toolbox tube clip
LuisPaz
Post by LuisPaz »
Once again I request your help with measures to reproduce the clip. Any drawing? Hole size? Nut and bolt?
Lenght between both clips?
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
john.nash
Re: 6560-41 toolbox tube clip
Post by john.nash »
John Nash
AOMCC No.4119
alan.moore
Post by alan.moore »
Mariano....just a tip, sometimes if the toolboxes are not WNG originals they don't line up correctly with the original brackets fitted. Try making a couple of brackets out of thin scrap aluminium first to get the alignment correct then make out of steel. Don't forget the L shaped bracket from the rear of the top box to the mudguard stay (6561-41) and the reinforcing metal strips 6565-35 that fit inside the toolboxes under the bracket securing nuts.
I will send you the rear mudguard measurements this weekend
Alan
LuisPaz
Post by LuisPaz »
John , Alan thank you very much for your reply!
Today I made the clips according the WNG pics found on Google.
Seems to be I have a good eyes .... :lol:
1944 Ariel WNG
LuisPaz
Post by LuisPaz »
Some pics to see the development
Relocating holes...
Thank you very much for your helps!
1944 Ariel WNG
Post by JohnnyBeckett »
HI Another very good job you have made again 8-)
alan.moore
Nice job :D
LuisPaz
Post by LuisPaz »
Thank you Alan!
Today reinforce clips with more welding!
1944 Ariel WNG
