6560-41 toolbox tube clip
- LuisPaz
Once again I request your help with measures to reproduce the clip. Any drawing? Hole size? Nut and bolt?
Lenght between both clips?
Thanks in advance!
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
- john.nash
Re: 6560-41 toolbox tube clip
John Nash
AOMCC No.4119
AOMCC No.4119
- alan.moore
Mariano....just a tip, sometimes if the toolboxes are not WNG originals they don't line up correctly with the original brackets fitted. Try making a couple of brackets out of thin scrap aluminium first to get the alignment correct then make out of steel. Don't forget the L shaped bracket from the rear of the top box to the mudguard stay (6561-41) and the reinforcing metal strips 6565-35 that fit inside the toolboxes under the bracket securing nuts.
I will send you the rear mudguard measurements this weekend
Alan
Alan
- LuisPaz
John , Alan thank you very much for your reply!
Today I made the clips according the WNG pics found on Google.
Seems to be I have a good eyes ....
1944 Ariel WNG
1944 Ariel WNG
- LuisPaz
Some pics to see the development
Relocating holes...
Thank you very much for your helps!
Relocating holes...
1944 Ariel WNG
1944 Ariel WNG
HI Another very good job you have made again
- alan.moore
Nice job
- LuisPaz
Thank you Alan!
Today reinforce clips with more welding!
1944 Ariel WNG
1944 Ariel WNG
