Nh 350
Nh 350
Evening all help needed out for run on the nh done about 20 mls and it stopped no spark left it over night ,next morning it started 2 kick I suspect the mag is there anything I can replace on it or is it a rebuild that's needed,cheers Peter
Re: Nh 350
Likely the secondary windings are cactus.......get an exchange armature from one of the repairers.
- chris.shearwood
Re: Nh 350
I suspect the condenser in your magneto is defective. This is a good web site for more info:
http://www.brightsparkmagnetos.com/
1946 4G and 1951 VH
Re: Nh 350
Thanks Chris have you had or anyone else had dealings with brightspark, ,I'm looking to get my mag reconed any recommendations would be greatly appreciated
- Bob.Murphy
Re: Nh 350
Earlier this year I built up four modified MO1 Mags from parts with 'Brightspark' condensers - They produce good sparks.
The trick is to remove the original condenser and replace the coil connections with something set in an infill medium. I experimented with 'Clearcast Plastic' (too brittle), a machined nylon block (too difficult to machine to a good fit) and finally epoxy resin (preferred). I learned a lot.
Regardless of my OCD experimentation the actual 'Brightspark' condensers are good .
(I wouldn't recommend building a mag from disparate parts - the bits don't fit together well or run true and there are a surprising amount of design changes over the years. My lathe & mill had a lot of work to do).
Re: Nh 350
Thanks Bob I don't have access to a lathe so looks like I'll have to send it off and have it repaired ,any recommendations as to best place to get it repaired
- alan.moore
Re: Nh 350
PeterPetebarn wrote:Thanks Bob I don't have access to a lathe so looks like I'll have to send it off and have it repaired ,any recommendations as to best place to get it repaired
I have had three done by Tony Cooper and have always received a good service and decent price
have a look at this post for details
http://forum.arielownersmcc.com/viewt ... ony+cooper
alan
Re: Nh 350
I had a magneto for my BSA Sloper done by Brightspark. It didn’t require much - a good clean and replacing the original condenser with one of their solid state ones. I was quite happy with the service and communication and never had any problems with the mag anymore. This was about 2 years ago.Petebarn wrote:Thanks Chris have you had or anyone else had dealings with brightspark, ,I'm looking to get my mag reconed any recommendations would be greatly appreciated
Gui
1951 Ariel Square Four MKI
1954 Ariel NH Red Hunter
1929 BSA Sloper
1946 BSA B31 (project)
1954 BSA C11G
1960 Harley Sportster XLH
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
Re: Nh 350
Just been through similar on my NH350. I found a local vintage tractor enthusiast who looked at the mag and found the magnets were weak.
He said my mag had been rewound. Also the bearing shorted to earth sometimes. The tractor guy had built a jig for magnetising mags. I did also have a carb problem.
Re: Nh 350
Thanks for info I'll give Tony cooper a ring next week as it looks like bright spark are in France so postage could be expensive
Users browsing this forum: dave.owen and 0 guests
