Hello Everyone,
I installed a Thorspark Ignition on my Sq 4 and was very happy with it. Easy starting, ran great. A few days ago the engine just died while in top gear, all lights out, all electrics dead. Fortunately I was just about to turn into the street where I live so I didn’t have to push her very long.
Anyway, the fault was traced first to a blown main fuse, and later to a short inside the pickup sensor of the Thorspark. Even with the base plate out of the distributor, and all other electrics isolated, the main fuse still blows as soon as the ign is turned on, i.e. as soon as the sensor gets power.
What are your experiences with Thorspark? Any similar problems?
I’m running 12V electrics and negative earth.
Cheers,
Gui
Sq Four MkI and Thorspark Ignition
1951 Ariel Square Four MKI
1954 Ariel NH Red Hunter
1929 BSA Sloper
1946 BSA B31 (project)
1954 BSA C11G
1960 Harley Sportster XLH
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
- Brian_Walker
Re: Sq Four MkI and Thorspark Ignition
Check the coil, insulation might be crook and causing short. See if it blows fuse with the coil disconnected.
1951-52 VCH under restoration
