Engine Breathing Singles - return to oil tank
- Keith.owen
Hi,
I fitted a Yamaha reed valve to my VH (crank case breather) and it has been quite successful in as much the engine is now pretty oil tight. It does however eject some oil from here all the same and I was wondering if anyone had experimented with returning the crank case breather back to the oil tank?
Has anyone tried this and what has been their experience?
Keith
Keith
Keith Owen
Editor Cheval de Fer
1950 Rigid Ariel VH
1950 Rigid Ariel VH
- steve.clarke
Re: Engine Breathing Singles - return to oil tank
Hello Keith
I capped off the oil supply tank outlet to the FERC on my VH and ran the breather hose from the Reed valve to the FERC connection to oil the chain worked fine, thought I might try connecting the outlet to the oil tank via this connection next time to see if it had enough force behind it to push the oil back to the tank.
Steve
Steve
57VH 58VH 56HS IN A 58FH Frame, mortal remains of a 57NH 1999 FZS 600
There's stuff coming out of the breather I wouldn't want in an oil tank. Nev
- adrie.degraaff
There is water-oil mix coming from the breather.
- steve.clarke
Regards Steve.
- chris.vredenbregt
Something wrong?nog video
- chris.vredenbregt
Something wrong?no video
- steve.clarke
Chris
I'm no expert, but when I look at the post it says unsupported plug in and below that play quick time file, maybe i have to save it as something else? will try again if others have a problem viewing.
- alan.moore
I think for a video to play direct on forum yo need to post it to YouTube and then put the YouTube link in the post.
However, if members left click on the IMG_2460.m4v file name in Steve's post it should download the video to their computer and they can left cliick on the downloaded file and play it from there.
Alan
Alan
- chris.vredenbregt
No result I am afraid wont play.....Chris
