W/NG Choppy
W/NG Choppy
Better start a separate thread about the W/NG
A few pictures as a starter:
The bit I have is straight.....
Underneath all grime the alloy still looks pretty.
Never noticed before that the crankcase halves number also is used in the camshaft housing.
Poured some oil in the bottom to see if it will loosen up a bit...
Frame and engine numbers tie up with the factory record, in itself a small wonder as most of the time things got for ever separated at the REME workshops
Re: W/NG Choppy
Post by Paul Slootheer »
I guess you where afraid to run out of projects :lol:
...is this another ''jusche gem''?...
adrie.degraaff
Re: W/NG Choppy
Post by adrie.degraaff »
It lookslike the rear is cut with a torch, to demobilise war material?
Eero.Korhonen
Re: W/NG Choppy
Post by Eero.Korhonen »
I think you need a new frame for that. :mrgreen:
Br, Eero
Re: W/NG Choppy
One can never have enough Ariel projects.
The Hermanator, the KH ánd this one will get done eventually :D
A few bits of 1" tubing will solve this :|
Yes it's torched off, it left the works on the 15th of May 1944 in slightly more complete order :shock:
Inside it looks 'o.k.'
These come in handy now.
alan.moore
Re: W/NG Choppy
Post by alan.moore »
Vincent re "Never noticed before that the crankcase halves number also is used in the camshaft housing".
What a great bit of info...just checked my 1939 VH and I also have a match :D
So this must mean the camshaft plain bearing housings were line bored with the inner timing case assembles to the crankcase and / or the camshaft plain bushes were line reamed after being fitted. Whatever the case a nice piece of history. Got to be worth a few brownie points in the originality stakes :D
alan
Steven.Carter
Re: W/NG Choppy
Post by Steven.Carter »
At least whats left of the frame looks straight :D
You'll have fun with this bike, good luck.
Re: W/NG Choppy
You bet I have fun !
Bought a rear hub yesterday, it has a different brakeplate, anyone know what make this is ?
It fits and looks substantial, but not Ariel, or is it ?
Re: W/NG Choppy
found it, brake plate is from a BSA M20
swop for Ariel rigid brake plate ?
Re: W/NG Choppy
CP gearbox :
Looks like I have a outer and inner from two different boxes.
But what year are they ?
XICPBL 42953
XICPBL 96991
