I am looking for the following if anyone has bits they are not using.
Thank you.
Ray
Inlet rocker box complete 845-38
rocker feed oil pipe VH 140-38
Push rod tubes VH 500
head bolts 4 off 3/8” x 3.00”
rocker box covers 2 off 857-38
rocker box bolts 6 long - 5/16” x 2 7/8” 2 short - 5/16” x 2 5/8”
1938-46 VH parts required
- ray.tolman
- dave.owen
Re: 1938-46 VH parts required
Ray, all of these parts apart from pushrod tubes are available from drags, try John budgen for the tubes.
Dave
Dave
- ray.tolman
Thank you Dave. The main part I require is the Inlet rocker box. The smaller parts I will order.
- dave.owen
Drags do remanufactured rocker boxes, I believe 10% off to members, they look very good.
Dave
Dave
- ray.tolman
Thanks Dave. I will check them out.
Ray
Ray
- dave.owen
- ray.tolman
Thank you Dave.
Ray
Ray
