Mystery Debris
Mystery Debris
So, what is this chaps? Looks a bit like bit of a pushrod cup:
Found while cleaning out the draining tray, after changing the oil in the W/NG. She seems to be running fine!
- Keith.owen
Re: Mystery Debris
Oh!!!
Keith
Keith
Keith Owen
Editor Cheval de Fer
1950 Rigid Ariel VH
1951 Rigid Ariel NH (under construction)
1950 Rigid Ariel VH
Re: Mystery Debris
Has anyone got a handy picture of an Ariel pushrod? I'd like to be sure that is really what it is, before I go pulling the rocker boxes off...
- Steven.Carter
Re: Mystery Debris
Looks a bit flat to be anything from a pushrod. To me it looks like the flat bit on the rocker that's pushed down by the valve lifter.
Re: Mystery Debris
If it is part of a pushrod, or the flat bit off the exhaust rocker, how did it get into the sump?
The one item I have found in the sump is pieces of the cylinder skirt, broken off when some piston debris got between the con rod and the cylinder skirt. There were no adverse effects on the engine running due to a rough "slot" in the skirt and it probably did about 10,000 miles after the breakage.
You might find it worthwhile to poke a piece of wire or similar around the bottom of the crankcase via the sump plate hole to see if there are any other bits lurking in there.
Re: Mystery Debris
What's the chance it was 'lodged' somewhere on the bike and fell in? Is it cast? Can't quite see if it's got a broken edge all the way round.
Re: Mystery Debris
What made me think of the pushrods was that it is cup shaped, about the right size, and it's polished inside...Steven.Carter wrote:Looks a bit flat to be anything from a pushrod. To me it looks like the flat bit on the rocker that's pushed down by the valve lifter.
Well, to be honest Paul, it was in the roasting tin I was using under the bike. It could easily have come from the timing chest.paul.jameson wrote:If it is part of a pushrod, or the flat bit off the exhaust rocker, how did it get into the sump?
It's got two broken edges and a machined beveled edge; the outside of the cup (the bit you can't see) is not polished, just a dark bare metal.roger.fellows wrote:What's the chance it was 'lodged' somewhere on the bike and fell in? Is it cast? Can't quite see if it's got a broken edge all the way round.
Having convinced myself, and attempted to convince you all that it was bit of pushrod cup, I can't see that the engine would run for long before the rocker bounced out. I drove it for a couple of miles yesterday and it pulls like a train. Well, a small train maybe, O gauge. Not like my SQ4, but it goes pretty well!
Re: Mystery Debris
A piece of push rod end could get into the sump. There's a couple of large enough holes in the timing side case. Check it's not marked by contact with the timing gears as you don't want it to go there at all.. Its hard and could fatigue with age, and a piece chip off. To be sure (repeat if you're Irish) pull the rocker boxes. (Only one if you are lucky) Take crook pushrod out, swap a new one (or fix (replace)the end of yours). There are slightly different lengths due the cam base dia variation. I would still clean out the camcase as you don't want any metal chips left there. That involves a magneto retime unfortunately. Nev
- adrie.degraaff
Re: Mystery Debris
I agree with you that it's the cup of a follower, the only way it will get in the sump is when a previus owner took the engine apart after damage leaving the crankcase in the frame and this part fell in the crankcase without him notising.simon.holyfield wrote:Having convinced myself, and attempted to convince you all that it was bit of pushrod cup,
Maybe even shooting away from working it in the vice, we all had that happening.
Re: Mystery Debris
Cup of a follower or cup of a pushrod? Doesn't it look a bit thin to be a follower cup? I'll get some better pictures later.
The timing chest has had a good clean out, and the cam has been out; the teeth are all good. Unfortunately I can't find any pictures of the followers, which is irritating - as you will i have seen i take pictures of everything!
Best I can do - shame I didn't take one before the gasket went on, but there's no obvious damage:
