Cleaning out my oil tank, I noticed the drain plug has a built in help function:
Do they all look like this?
Drain Plugs
Drain Plugs
Re: Drain Plugs
It's usually on the outside. Hard to see the "writing" on it from the inside especially if the oil is in need of draining. Perhaps the kid doing the stamping was new at the job. Nev
Re: Drain Plugs
It's on the outside - you can't see the hexagon in the picture because I hadn't cleaned it.
Do all drain plugs have that stamping or is it a military thing? I haven't noticed it on my other Ariels but then I can't say I've looked...
Re: Drain Plugs
I've only seen it on the military stuff, but that's not conclusive. Nev
Re: Drain Plugs
It's like those stickers on cars; "When you can read this" ...... you have drained the tank !
Re: Drain Plugs
On the older Harley gearbox it says "keep filled". Should have that on your beer mug, steiner etc Nev
