1958 FH Shrouds & Engine mods
I'm rebuilding a 1958 Huntmaster.
I have 2 identical fork shrouds, one drilled one not (BSA?), 2 'spacers' drilled and counter-bored same OD as shrouds and bottom yoke. The bottom yoke has the 3 holes. The spacers will fit on top of the shrouds underneath the yokes. The parts lists I've seen show the shrouds as being one piece.
Will some more experienced members please answer a couple of questions? I have, hopefully, attached 2 pictures to assist.
Have I got BSA items? Do the springs bear on the shroud fixing screws? Are the spacers required (why have counter-bores)?
Also I have an HCS engine which I'll probably get SRM to rebuild and carry out the timing bush mod.
I believe the HCS is Super Rocket spec, I've heard stories about thin flange barrels on BSAs.
Should I be looking to fit the BSA thick flange ones?
Any comments would be appreciated.
Thanks
Dave
Thanks
Dave
Hi Dave,
I can't help with the shrouds but I know BSA barrels fit, but look really weird as the fins stick out way past the fins on the Ariel head. The PO of my Huntmaster put on BSA thick-flange barrels and a BSA Super Rocket ally head -which plays havoc with the exhaust pipe run. AFAIK Ariel didn't make a 'Ariel thick-flanger' (although someone may know different) so you would have to buy a BSA part and shave the fins down.
Richard
Richard
- keith.mettam
Hi Dave,
From memory when rebuilding my 1957 NH forks, the 'spacers' are fixed inside the top of the shrouds and as such are part of the shrouds. The shrouds are attached to the lower fork yokes by three small screws which are countersunk in the so called spacers so that each spring bears flushly on the spacer. You will need a long screwdriver to tighten the shroud mounting screws up prior to fitting each spring etc.
Regards,
Keith Mettam.
Regards,
Keith Mettam.
Re: 1958 FH Shrouds & Engine mods
Thanks for your help.
With regards to the Spacers, they will not fit inside the shrouds I have.
So, something's not right!
Moto Guzzi EV California, Suzuki GS750, Ariel FH 'Clone (WIP)
- keith.mettam
If you look at this DraganFly link you can just about see the arrangement at the cutaway area of the shroud on the right in the image. Screw is item 081 (x6 as 3 per shroud).
http://www.draganfly.co.uk/images/shop/ ... 056-58.gif
Perhaps the spacer parts you have are not Ariel ? Can they be machined to fit ? I seem to remember that the parts in the top of each of my shrouds were thicker than your items.
All the best with it !
Keith.
Keith.
- keith.mettam
- john.nash
I just put together some early fifties forks.
I didn't have shrouds and spacers as separate parts (probably rusted together) HOWEVER there must have been something in there it was thicker at the top, than just the shroud thickness, and there was countersinking as on your spacers. It has to be countersunk otherwise the springs would bear directly on the screw heads and probably break them off over time.
BTW, I screwed them in with a long screwdriver and some bluetack to hold screw to driver !
The answer might be to buy some more shrouds (secondhand) or more likely a complete lower yoke with shrouds.
My bike came without and I got a set from John Budgen for £20 (2 months back)
John Nash
AOMCC No.4119
AOMCC No.4119
- keith.mettam
