Hi all
Has anyone got a wiring diagram with the switch movement for a 1961 Arrow, I have one for the TS model but the Wire configuration is different.
Thanks
Alan
Arrow ignition switch movement 1961
Re: Arrow ignition switch movement 1961
This is a November version
hope it helps
regards
Dave Smewing
hope it helps
regards
Dave Smewing
Hi Dave
Thanks for that unfortunately this is the same as the one I have that states it for the TS and the rectifier and ignition switch wiring is different.
Thanks
Alan
Thanks
Alan
I have finally found the problem the battery that was flat after my rebuild has decided to change poles + pole now negative and - pole positive,
has anyone had this before?
