WNG
Re: WNG
To all.
Thank you for the response.
If some one have interest in the plate I will swap ore sell it.
Jorgen
Jorgen
Re: WNG
OK, Nev, got an extra "TEST" switch under the bench?
Re: WNG
Sorry Wade, I didn't see this post and reply to you at the time.. If I can get another switch with TEST on it I will get back to you. I'm looking for the "P" push button switch and the blanked plate where the ammeter used to go. Incidently I've found the lights go from the Mainbeam filament (One wire only of the two connections) to the park filament, not high and low beam. This info is in the Maintenance manual for the W/NG (101/A1. 3B). the "test" operates the tail light IF the generator is working. the full wiring info is also in the above publication. There is only ONE wire shown going into the headlamp shell, but I would also run an earth wire, myself. regards Nev
