Hi peoples ,
Can anyone with a 1955 NH 350 or VB or thereabouts, measure up the length and width please, I,ve got a trailer thats 59'' long by 49'' wide, in English please note.
Bit of wishful thinking, about picking one up but I,m moving, hopefully, form the Outer Hebrides, down to Blackpool area,and though it was a bit more conducive to bike riding!
My father in law up in N.Devon, had a Morris 1000 pick up, and bolted a U form, bit of RSJ, to the floor,straight, from front to rear of the PU bed, 2 lifted front wheel on, pushed, then lift rear on, so easy!! So I thought I might do similar to the trailer if it,s a bit short.
Thanks ,In anticipation
Vaughan
dimensions of NH 350 or Vb
- Steven.Carter
Re: dimensions of NH 350 or Vb
My Huntmaster which has the same frame is 86'' long and 28'' wide at the handlebars.
Steve
Steve
Where there's will there's a way. I've lengthened trailers as you described.
Much obliged to you both, now to find a bit of RSJ?
You dont need the trailer to go to the far end of the bike ,just long enough to get the spindle over the end and let the rest hang over.
Ian
Ian
True, that'll save me a foot or so, and I'm sure I can find 76'' or so long to act as a channel to steady the bike
Just found something on THAT web site, a conversion that fits over the towing ball, you put the front wheel onto that, and you tow it using the back wheel of the bike on the deck and turning, mind you £260 including postage from yankeeland seems a bit excessive
