Sounds like a plan now, thanks to all concerned
John
Burgess air filter box
- steve.clarke
Re: Burgess air filter box
A few photo's if they are any help.
Cheers Steve.
Thanks Steve, those pictures are just the job.
Cheers John
Cheers John
Hi John
There are two different sizes or air filter box fitted to s/arm machines but the length of the bracket changed to ensure that the overall spacing of the two top and bottom mounting holes was the same, the complete boxes are therefore interchangeable but you cannot mix bottoms and tops. The filter rubber hole on the flat face is for a VB, the hole on the top horizontal edge is for an OHV single (NH, VH & HS)and the hole on the vertical side edge is for a twin (KH and FH). For the OHV singles version the part number changed in 1955 but for the twins the 1954 part number remained the same.
Ben
Ben
Thanks Ben, I have now modified my filter box by grinding and making the hole up onto the top. The rubber fits OK now so I will refit it, and hope nobody notices.
Cheers John
Cheers John
