John Budgen
- john.nash
John Budgen
John Budgen
http://www.johnbudgenmotorcycles.co.uk/
He tells me that he is having made:
1175-26 engine m/s nut LHT
1755-90 VH cam with 1770-34 pinion
1800-51/1801-51 re-profiled followers - exchange
1855-50 pushrod
1890a-58 pushrod seal - top hat
1903-38 pushrod tube - stainless
1905-38 pushrod tube - stainless
2090-53/2098-55 mag oil seal with retainer
210-53 mainifold not - stainless
2461-53 side stand spring
2462-40 Field stand clip
2504-54 centre stand spring
3068-50 clutch centre nut
3070-50 clutch centre lock washer
3091-33 gearbox sprocket lock washer
335-30/341-38 exhaust lift spindle/bush
3389-41 chainwheel lock washer as per original
3391-36 bolt - clutch basket
3405-54 clutch springs
3413-31 clutch spring retaining screw
3420-37 needle roller cage
3423-36 clutch rollers
348-54 exhaust lift lock washer
4402-36 brake arm
4665-26 girder fork damper disc
4665-34 fork daamper disc
4854-34 nut - flexible hnadlebars - stainless
4856-34 handlebar packing - stainless
4903-35 damper rod end
4989-54 wheel adjuster
5382-56 HT footrests
5387-56 HS footrests
5510-30 rear stand spring
5591-35 stay for hinged mudguard
5655-30 stud
5656-35 nut
5874-55 armoured oil pipes
6107-56 battery strap - stainless
6107-51/6108-51 battery straps - stainless
6560-36 toolbox brackets
6560-40 toolbox brackets - W/NG
851-54 plug - rocker box
945a-31 rocker collar
9000-54C Air filter box -VB
9000-55C Air filter box - NH;VH; HS MkIII
9000- Air filter box - FH
9009-56 Air filter box - HT
D-2713 BTH adv/retard plunger assy.
H45-46 front mudguard stay
S2-7L pinion nut
500cc alloy barrel
500cc alloy barrel - short stroke
500cc alloy head
Burman Trials wide ratio gears
HT sump shield
W/NG sump shield
Dunlop replica rubber trials saddle
Dunlop replica large rubber saddle top (HRD etc.)
pannier frame brackets W/NG
rear mudguard bridge under saddle
rear mudguard bridge under mudguard stay
girder fork mudguard bridge
I am also investigating the possibility of making some early footrests and stainless steel fork seal holders.
1855-50 pushrod
4402-36 brake arm
5655-30 stud
5656-35 nut
S2-7L pinion nut
500cc alloy barrel
500cc alloy head
HT sump shield
W/NG sump shield
John Nash
AOMCC No.4119
AOMCC No.4119
- steve.clarke
Re: John Budgen
Any one know how to contact John? looking to buy some 1890a-58 top hat for the push rod seals his web details are out of date ?
Cheers Steve.
Cheers Steve.
- charles.bulloch
- charles.bulloch
- steve.clarke
Re: John Budgen
Just taken a look at the website, address has changed and new number Pulborough Sussex, I thought to use them as I have a scuffing EX pushrod,but that may be because my VH had no rocker box gaskets, do you think it's the top hats that are causing the leak Charles?
Steve.
Steve.
