Iphone Charging.
Iphone Charging.
Has anyone tackled charging an Iphone (5.25 volts) directly from six volt system? If so what resistors did you use to drop the voltage? Any help would be greatly appreciated, i'll even buy you a pint.
Rob C.
Rob C.
1954 FH
- chris.vredenbregt
- brenton.roy
Hi Rob,
Assuming you want to keep the 6v electrics, you could put in a dc dc step up converter and a 12v outlet.
These are inexpensive via eBay etc. and you could also run goodies like a HID headlight.
See entertaining youtube video... http://youtu.be/p81fld-i-98
I bet that annoying Mr Carter has a fridge in his topbox ? ![Shocked :shock:](./images/smilies/icon_eek.gif)
Administrator
webmaster@arielownersmcc.com
- Steven.Carter
Re:
Annoying!!!! your just jealousadmin wrote:I bet that annoying Mr Carter has a fridge in his topbox ?
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Iphone Charging.
Hi I purchased a stablised voltage supply 7V-24V to 5V 3A DC-DC Step Down Converter Buck Module with USB Output KIS3R33S ebay item number 281216550302, for £3.49 worked a treat for my TomTom.
