I hope to restore a tank for a 1958 NH. I have never had the knee grips off a late tank. I would like to know how they are fitted to the tank. I suspect that the chrome surround screws onto the tank and the rubber is then pushed into the surrounding frame. I would appreciate any help with this.
Thanks Ian
LATE 58 SINGLE TANK KNEE GRIPS FITTING
- robjameson
Re: LATE 58 SINGLE TANK KNEE GRIPS FITTING
The alloy surrounds are just sandwiched between the tank and knee grips, there are no screws, but I suppose you could silicone them on if you choose.
When replacing the knee grips I found using a bit of para cord fed in to the head of the knee grip helps to seat them (like you would fit a window to an old car) this worked on mine and 1000+ miles later is still fine.
Let me know if you need any more explanation or anything.
Rob
Rob
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
- robjameson
- keith.mettam
Thanks for your help. I now understand what I am missing is the flange plates. On the tank I have they are missing and the welding marks have been sanded and filled. I notice that there are some NEW ARIEL 350CC PETROL TANK KNEE PAD'S MOUNTING PLATES (REPRODUCTION) on ebay from India. I think I will stick the knee pads onto the tank directly with a contact adhesive like Evostick without the flange plates.
Ian
Ian
- Steven.Carter
If you go down the line of gluing the rubbers on I can recommend this stuff, http://www.ebay.co.uk/itm/like/15107667 ... =83&ff19=0
I've used this stuff to glue on some small pieces of leather to my tank to prevent cables damaging the paintwork.
Steve
Steve
