Hi Brian,
Sometimes my Yahoo account bounces emails and I have no idea why? I have only just acquired the Arrow and as yet have not made contact with any other Australian owners. Regarding the special tools, I can make most of them myself, probably even the plate and pin providing I had dimensions for the pin in particular as it appears to shave a flat cut into the end? Having a PayPal account attached to your site is a bonus. Once again thanks for you assistance.
Garry
Ariel Arrow mains and seals
Re: Ariel Arrow mains and seals
Hello Garry,
The postage on the plate and pin are ---- £18-95 air mail and around £ 12 -00 for the surface mail. Its a lot of money if you can make things yourself.
I can give you the dimensions for the pin , the ones for the plate will take a bit longer, I now have a jig for drilling the holes which saves a lot of time , so I do not have the dimensions to hand.
The pin is 1 inch diameter and 4 inches long , the end section where the cut off section is , is reduced a bit around 10 thou (.010) to aid location into the flywheel holes. The cut off section is 1.312 inches long and approx .187 deep measured from the edge . Its there to allow the pin to clear the big end.
Regards Brian.H.
Regards Brian.H.
