kickstart and Speedo problem 1946 4G SQ4
Briefly, the kick-start has started to rest against the back of my leg when riding, so I assume an internal bracket/stop has broken/dropped off.
Before I take the gearbox cover off, any warnings or hints/advice please
Also while off, I’m going to examine the worm drive for the Speedo as despite new cable and overhauled Speedo the needle just occasionally rattles around, again any hints /warnings would be great.
Thanks for reading
Reg
Thanks for reading
Reg
Taking the outer cover off is pretty straightforward. The gear change part may come with it and have to be re indexed but it is marked. You can then check the skew drive gears for the speedo. If you are lucky the end of the cable will just be a bit short, but often the gears are stuffed. They are very hard steel and crack up . Nev
In my blog post 'spend a night in the box' there are some views of the kickstart stop.
Re:
Nevnevhunter wrote:Taking the outer cover off is pretty straightforward. The gear change part may come with it and have to be re indexed but it is marked. You can then check the skew drive gears for the speedo. If you are lucky the end of the cable will just be a bit short, but often the gears are stuffed. They are very hard steel and crack up . Nev
You were right, despite trying to not pull the gear change out, it pulled off with the cover.
The drive coming through the box to drive the Speedo cable worm is damaged (see photo) as is the worm drive (you were right again)
Thanks for your input, enjoyed reading your blog, very useful.
on taking the cover off the first thing to dribble out was some water before the oil/grease mix, I realised why when I saw the hole where the kick start stop should have been (no damage), no sign of the bolt, but found the rubber made from an oil pipe and the squashed outer ring, see photos.
Re:
Johnadmin wrote:http://forum.arielownersmcc.com/viewt ... =36&t=1660 ?
When I try to follow the link I get the following message "You are not authorised to read this forum." I have logged in.
Thanks Reg
- brenton.roy
Re:
Thanks Brentonbrenton.roy wrote:Reg, this is in the AOMCC members section.
If you are a member, let John know - he'll give you access and paint your name red.
When I click on Members at the top right of the screen I do come up as a registered member, I will ask John
Reg
Re:
Hisimon.holyfield wrote:In my blog post 'spend a night in the box' there are some views of the kickstart stop.
Did your new kickstart stop peg, work ok I.E. no loud clanks etc when releasing the kickstart, or damage to the mechanism not having a buffer to hit rather than solid metal.
I have to make a choice of doing something similar to you or buying a box (allegedly working fine) I have been offered for £100.00
Is this the going price for a box ?
Thanks
Reg
Re: Re:
Is that a BA box ?Reg.Webster wrote: I have been offered for £100.00
Thanks
Reg
If you didn't want if, for that money, then I would
Not exactly easy to find, complete ...
Administrator
webmaster@arielownersmcc.com
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 0 guests
