I have an Ariel mod A 1929 557cc. The gear box is a Sturmey Archer LS 250. What lubrication is recomended and how much?
Hans
What lubrication for my Sturmey Archer gear box?
- chris.vredenbregt
Re: What lubrication for my Sturmey Archer gear box?
Castrol Spheerol L/EP 0
- huw.parsons
Miller Oils do a semi fluid grease too, I seem to remember it is a little less expensive than Castrol Spheerol.
I Fill my Sturmey box up to the plug. It then spits out what it doesn't need and seems to stay at much the same level thereafter.
Many thank´s!
Hans
Hans
If all the gears on the lower shaft can dip into it, it will get around. It will be fluid when the gearbox get warm.
