Hi there,
I have just stripped down my Lucas 3L dynamo and it is filthy inside, being full of grease mixed with black 'soot'!!
The question is 'what can I safely use to clean / dissolve this out without risking damage to the insulation on the field coil and the commutator windings?
I had though of using IPA (Isopropyl alcohol, not beer) but need to be absolutely sure...............I don't want to ruin it (especially since I have buzzed out the windings - Commutator about 0.6 ohm, field coli about 2.7Ohm) since apart from the filth it seems electrically OK.
Any thoughts?
Thanks,
Keith
What is safe to use as a cleaner
- Keith.owen
Keith Owen
Editor Cheval de Fer
1950 Rigid Ariel VH
1950 Rigid Ariel VH
