Lodge plug
Re: Lodge plug
Post by JohnnyBeckett »
hi you have a problem with NGK plugs you mite need a hotter plug you can be running to rich or burning oil if i have a problem that i ring NGK and get their advice on what ones to use and they have not let me down yet i have used all makes of plugs in my workshops in my lifetime and NGK comes out tops with me and my racing team :!:
pappleton
Re: Lodge plug
Post by pappleton »
I switched to NGK's many years ago, with no regrets. I used to run a service station in the U.S. the amount of dud Champion plugs was quiet significant. I attended many rallies both here and abroad, clocking up mileages approaching Mr Carters. I found that the electrodes on Champion plugs just plain wore out, no such problem with NGK
BR,
Paul
EricBorg
Re: Lodge plug
Post by EricBorg »
Evening all,
I’ve come across these two Lodge SINTOX C14 plugs, the mate who gave them to me said he took them out of a WW2 outboard motor. Still has some of its war time green paint.
Had a quick comparison next to the NGK B6HS that’s on my bike and they are the same length and size.
So I just had to try it and what do you know, it fired right away, seemed to work well with it but I turned it off straight away as I know it’s not correct, when I made a cross reference from the Lodge C14 to an NGK, the equivalent is NGK B5HS.
Would this plug be too hot/cold for the WNG??
Re: Lodge plug
The bit you have to be concerned about is the length and thickness of the insulator in the combustion chamber. If it's long and thin it is a HOT plug only used in some (older) two strokes. An OHV Ariel needs middle to cold depending on how you ride. (Revs and load). A too hot plug can cause detonation, loss of power and engine damage.. Nev
Re: Lodge plug
them plugs look like aircraft with 3 electrodes with high voltage ignition :!:
Re: Lodge plug
them plugs look like aircraft with 3 electrodes with high voltage ignition to run them :!:
Re: Lodge plug
Multiple electrode plus were common at the time. They are generally considered to be of no practical advantage, and difficult to adjust the gap(s) Nev
Pete.Silson
Re: Lodge plug
Post by Pete.Silson »
They are generally considered to be of no practical advantage...
They are however easier to clean since the central electrode/insulator unscrews from the body.
Pete
Re: Lodge plug
what i have found with multiple electrode plugs you can get a misfire and you get a weaker spark if you have not got a good mag or coils and Leeds and caps :!:
