The photograph is of the washer used to seal the banjo joint on the rocker oil feed pipe on my W/NG. It is 1/32" thick, 3/8" ID and 7/8"OD. As far as I can tell, It is not made of metal or copper or fibre. It is very hard and low friction.
It does create a very good non leaking oil seal. However, I only have 3 and need 4.
Does anyone know what material this might be and whether they are available anywhere?
I have tried the usual internet sources without success.
In the same vein, I could use a fibre alternative, but I read that fibre washers should only be compressed and not subjected to a turning force. I assume a washer between the nut and the fibre washer would solve that issue?
Washer material and application
Re: Washer material and application
hi i think they are a hard fibre washer if you can not get them off the clubs spares or drags , you will get them off a washer
and gasket maker or look on ebay or try looking on Google and you will get them
Put two fibre washers between the boxes and the banjos (where they're not subject to compressing/turning.
That leaves 3 of the old washers to put elsewhere...
(You don't need any washers between the banjos and the nuts - as long as you've got yellow-metal banjos and 'unmolested' original-style acorn nuts on the spindles.)
Thats a good idea Simon, Ill give that a go.
Thank you
Thank you
