Thanks Dave,
I had.not seen it, but was going to call IMD anyway to het the liners and pistons. Sounds good.
Gui
Sq4 MkI - engine blow up and rebuild
Re: Sq4 MkI - engine blow up and rebuild
1951 Ariel Square Four MKI
1954 Ariel NH Red Hunter
1929 BSA Sloper
1946 BSA B31 (project)
1954 BSA C11G
1960 Harley Sportster XLH
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
Good morning, Gui.
I'm glad that things are not too bad. Thanks for the picture of the sump filter, which appears to be an original one (a proper fit, unlike others which are available.)
Btw, has the roller bearing on the end of the crankshaft been removed when you stripped the engine and replaced for the photograph? It appears to be fitted 'inside out.'
I have a spare cam follower guide block surplus here which you can have as my contribution to your rebuild. Let me know if you want it and I will post it to you.
Many thanks Paul for that great offer. However I have 2 good ones in my old block which I can use.
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
Back into the autojumble box for it then!
