Huntmaster timing side cover screws
I'm just about to refit the timing side cover on my Huntmaster restoration. I've got the 12 screws but not sure without a lot of trial and error as to which length goes where. Is there a diagram available? Any help much appreciated. Frank
Re: Huntmaster timing side cover screws
There's only three differing lengths of screw, just measure the depth of the holes to the mating face of the inner cover with a bit of stiff wire and it will all become obvious - so easy I didn't make a note of it
Doh! Why didn't I think of that? Just don't tell my wife!! Thanks a lot anyway.
hi i had the same thing when i was putting my engine and gearbox together i did look at Drags site but i found the listing of screws not a 100% right so i done the same as what Mick says
