Hi, all.
When doing the pleasant job of mounting the magneto to a single, should I use spring washers on the screws?
Magneto bolts
- charles.bulloch
Re: Magneto bolts
Cannot see a real need for them, but if you do fit them, then fit them between 2 large plain washers to ensure that the magneto can slide easily on its mounting plate when it comes to adjusting the timing chain tension.
John P.
John P.
