Hi, all.
When doing the pleasant job of mounting the magneto to a single, should I use spring washers on the screws?
Magneto bolts
- charles.bulloch
Re: Magneto bolts
Cannot see a real need for them, but if you do fit them, then fit them between 2 large plain washers to ensure that the magneto can slide easily on its mounting plate when it comes to adjusting the timing chain tension.
John P.
John P.
Users browsing this forum: Majestic-12 [Bot] and 4 guests
