Posting Images
Post here for help with using the Forum.
For help with a machine post in one of the technical sections.
Locked
admin
Posting Images
Post by admin »
Uploading your own image
This is the preferred method - linking to images already on the web only works while the image is available (lots of images that are links to photobucket etc. files no longer work)
Most file types are supported .
If you are uploading your own image, then you will need to "post reply" to existing message.
(NB 'quick reply' doesn't have the options, use 'Full editor & preview' )
You will get a big white space to type into.
A little below that white space are three tabs (options, upload attachment, poll creation).
select "upload attachment"
You can then hit the "browse" button to select the image on your computer.
Then hit "add the file"
Once it's uploaded, you'll have the option to "place inline" which will allow you to embed it among your text.
Uploading an image that is already on the web,
This method is not approved!
Please see the policy on external images:
viewtopic.php?t=13881
Re: Posting Images
Post by JohnnyBeckett »
HI John that is good to know i will have a go at doing that thank you
fgething
Re: Posting Images
Post by fgething »
Hello, new member to the four stroke club.
Last bumped by admin on Sun Jul 24, 2022 1:28 pm.
Locked
