Wheel Bearings 4040-27
- paul.wirdnam
Anyone know where I can get some of these taper roller wheel bearings from? Drags currently out-of-stock ...and no idea when back in...
OD 1.750, ID 0.562, W 0.562 (inches)
I was hoping to buy some standard taper rollers, and perhaps sleeve the ID and add shoulder, but there is nothing out there with 1.750 OD.
Thanks
Paul
Thanks
Paul
Paul
- paul.wirdnam
Thank for your input John; I'll get my digital calipers and Zeuss book out and look at the options. If I sleeve the OD, I'm assuming that will butt up against the step in the hub...and therefore I might need to also machine a small step in the sleeve to stop the bearing potentially pushing all the way into the centre of the hub...or is the hub step big enough to stop the sleeve and bearing?
Paul
- paul.wirdnam
Mmmm. I've got a couple of SKF catalogues; one dated 1968 and the other 1981. The 1981 one lists a few other possibilities like:
320/22 which has an OD of 44mm which is only 0.45mm under the required OD of 1.75 inches. 8 thou inch shim will take up that and this bearing will sit nicely against the step in the hub. And with an ID of 22mm, plenty of room for an inner sleeve with the required shoulder. It has the added advantage that its width of 15mm is close to the original bearing.
They seem readily available on eBay and have similar load characteristics to 30302 etc, so can anyone see a problem with this one
Paul
http://www.ebay.co.uk/itm/1163X-wheel-b ... 3a6a9e2f57
Check this out - also says he has different ID sizes.
KOBI
Swindon Branch Secretary
Velocette MAC, KSS Mk1
- paul.wirdnam
Re:
That's the one...but £200 for a set I'll make my own for a tenth of that...tony.barnett wrote:http://www.ebay.co.uk/itm/1163X-wheel-b ... 3a6a9e2f57
Paul
Re: Re:
Were Drags cheaper (when they had stock)?paul.wirdnam wrote:That's the one...but £200 for a set I'll make my own for a tenth of that...tony.barnett wrote:http://www.ebay.co.uk/itm/1163X-wheel-b ... 3a6a9e2f57
Be interested in what you end up doing. For my education - Any reason why they have to be taper roller bearings? The later wheels were ball bearings (I think)...
KOBI
