Has anyone seen this converted frame on eBay? Anyone know what it is?
https://www.ebay.co.uk/itm/144483684106 ... SwTSJiPJ9z
I'm quite tempted to build a trials bike out of it...
Converted Frame
Converted Frame
Re: Converted Frame
It looks to me as if the wheelbase might be a bit on the long side
for off-road use. There isn't a lot of room under the sump at the
best of times and this may well be less than a standard frame
let alone a W/NG.
It is an interesting bit of work and it would be nice to find out some
more about it.
let alone a W/NG.
more about it.
Re: Converted Frame
I'm not very keen on that platework, and this photo worries me a bit
I do find all the 're-engineered' stuff interesting (as long as it's been done properly). If I had the McCandless swing-arm Sq4 that Paul J has mentioned I wouldn't be wanting to turn it back into a rigid (especially considering the lengths people go to to create other swing-arm versions)!SG
Re: Converted Frame
Definitely with you on that one Simon, though rigid SQ4's are rather lovely.Simon.Gardiner wrote: ↑Fri Apr 01, 2022 1:14 am I do find all the 're-engineered' stuff interesting (as long as it's been done properly). If I had the McCandless swing-arm Sq4 that Paul J has mentioned I wouldn't be wanting to turn it back into a rigid (especially considering the lengths people go to to create other swing-arm versions)!
Re: Converted Frame
It might just be the angle of the photograph but the rear frame alignment looks a bit off to me.
Pete
Pete
Re: Converted Frame
hi it look like to me the frame is out of line unless it is the angle of the photo, like Pete says
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
