Wanted magneto sprocket and sprocket puller for V500
Re: Wanted magneto sprocket and sprocket puller for V500
hi dennis if you need a puller and you still cannot get one just pm me and i will send you my one to use, but lets hope you get one soon
I bought one of these:
https://shop.kingpincomponents.co.uk/ch ... r-sprocket
It means that the carrier can be fixed to the magneto shaft, then the nut slackened off in order to allow loose fitment of the sprocket with the pin to allow timing to take place.
For each movement of the pin, the timing can be advanced or retarded by 2.3 degrees, but always knowing the original set point. I'm still experimenting a little from the standard 1/2" BTDC.
hi , someone in the club had some made that you undid 3 allen key bolts and rotate the sprocket , i thought it is a very good idea
Julian,
That vernier sprocket looks interesting. The one shown in the link is for a Rudge did you buy that one because one for an Ariel single is not listed?
Dennis
Dennis
1955 VH500 alloy head
I have recently sold my 35 VH and have found a few more parts including a sprocket and puller. I will look it out this afternoon and get back to you
Ian Scott
Ian Scott
HI
I have looked out the VH parts and find I have a couple of pullers complete with sprocket . Let me know if your interested ,
I have a fair few other bits including a single cam and pair of followers , side valve follower and a couple of headlamp 3 brush relays. I will try and list it all over the weeked.
Ian
Ian
Ian,
Yes I am interested in buying the puller and magneto sprocket 1925-29 if you have them.
Pm me with a price.
Many thanks,
Dennis
Pm me with a price.
Many thanks,
Dennis
HI Dennis
Here are few of the bits and pieces I stil have , let me know if you want anything. Ian
Ian,
Pm sent.
Dennis
Pm sent.
Dennis
Yes. The Rudge one had the right number of teeth, and fitted perfectly on the shaft taper with the key.
