Wanted magneto sprocket and sprocket puller for V500
Wanted magneto sprocket and sprocket puller for '54 V500.
The sprocket 1925-28 and sprocket puller 6621-29 appear to be out of stock at Drags and all other suppliers I can think of.
Many thankjs,
Dennis
Many thankjs,
Dennis
1955 VH500 alloy head
Re: Wanted magneto sprocket and sprocket puller for V500
hi dennis try looking on ebay under Ariel parts i have got some good parts and tools off it
Johnny,
Good shout. I found a sprocket on ebay today but no success with the sprocket puller. Until I get a puller I can't get the cam sprocket off.
Dennis
Dennis
hi dennis SJ ENGINEERING does the puller and it works out cheaper the ebay number 193048125246 ebay number seems not to work and the ad says there is 2 in stock have a look or give them a ring on 02825 483175 i found them on GOOGLE i have got some Ariel parts off them in the past , now when i look at the ad it says none they may make you one quicker than Drags
Johnny,
I saw that SJ Engineering are out of stock on ebay so I gave up but I will give your suggestion to contact them directly a go.
Dennis
Dennis
I called SJ Engineering and a very nice chap said that they do not make the puller and they have had a back order with their supplier from some months.
I have found only two potential suppliers for a mag sprocket puller; one in Australia at some exorbitant price and one in Austria at about 25 Euros for the puller and 25 Euros postage. Still, if anyone is desperate they claim to have four in stock (British Only Austria).
Dennis
Dennis
hi dennis you could try getting on to your local AOMCC club branch and see if there is a local member that my lend you a puller ( if not and you get stuck let me know and i will see if i can find my puller and send it up to you and lend it to you )
Johnny,
That is very kind of you. I have removed the sprocket so I do not need the puller for now. I am going to continue to look for one on line because I will need a puller if I have to re-time the mag to the engine.
Dennis
Dennis
I find it better to free the camshaft sprocket for the timing adjustment and leave the magneto sprocket on it's taper There's no good way of holding the magneto armature when the sprocket's freed from it. and the camshaft taper is a much larger diameter. Nev
Nev,
Thanks for that. It had not occurred to re-set the timing that way. However, I will still need a puller for the camshaft pinion.
Dennis
Dennis
